Lock channel - Ultra Box / Ulti Box
On your remote, press the Home button and the home menu will be displayed on top of your screen.
Navigate to Guide.
Select the channel you would like to lock and press "OK".
Select "Lock Channel" and press "OK".
You channel is successfully locked when this screen appears.
STEP 6
Your selected channel will have a lock tagging after being locked.
