No Audio - Ultra Box / Ulti Box
Check the Audio settings on your box and set to Auto.
Refer guide to change Set HDMI Audio.
If issue persist, check if there is any 3rd party device (sound system/hdmi splitter) connected between box and TV.
If using 3rd party devices, bypass/remove 3rd party device and make sure HDMI cable connected directly from box to TV.
If issue persist, connect to Live Agent via WhatsApp for help.
