Refresh Box setting (Clear NVRAM) - HD enabled Box
Byond Box (DMT 5)
Switch on the power for your box and make sure that the adapter's power light is on.
Put the box on standby mode.
Press and hold the Home button on the box.
Wait until "boot" appear on the front panel and released.
New Installation Settings page will appear.
Click here for the guides to complete the setup.
Byond Box (DMT 4)
Switch off the power of your box and ensure the adapter�s power light is off.
Switch on the power of your box and ensure the adapter�s power light is on.
Press and hold the Ch+ and Ch- keys on the box simultaneously when the "boot" message appears on the front panel.
Wait until the "Clr" message appears on the front panel, then release the Ch+ and Ch- keys.
Byond Box (Zapper)
Ensure your box is on standby mode. (Red light on box's front panel).
Press and hold the Standby button. Wait until the LED at front panel change from red to green for 3 times, then release the button.
Byond Box (New Zapper)
Switch off the power of your box and ensure that the adapter�s power light is off.
Switch on the power of your box and ensure that the adapter's power light is on.
Keep pressing the 'Power' button until the Startup Option screen appears.
Press "369" on the remote control to trigger refresh box setting menu.
Press "OK" to proceed. The box will be refreshed to the original setting.
STEP 6
