Unlock channel - Ultra Box / Ulti Box
On your remote, press the ... button and the Channel Guide page will be displayed on your screen.
Select the channel you would like to unlock and press "OK".
Select "Unlock Channel" and press "OK".
Enter the PIN to unblock the channel.
You are successfully unlocked the channel when this screen appears.
