Check signal level - HD enabled Box
On your remote, press the “HOME” button and the home menu will be displayed at the bottom of your screen.
Navigate to SETTINGS and press “OK”.
Navigate to STB DIAGNOSTICS and press “OK”.
Refer to the signal strength % shown on the top left of your screen.
